Custom Busy Light( )?
Hello jmp community,
First of all, let me wish you a great new year!
I am currently working on a project and want to use something similar to busy light() function but with a custom animated gif.
The only way I find to animated a gif in a New Window() is to use this block of jsl  by incrementing the gif frame by frame.
spinner = New Image( gifpath || "\spinner.gif" );
nbFrame = spinner << Get N Frames();
For( i = 0, i < nbFrame, i++, spinner << Set Current Frame( i ); nwStatus << reshow(); wait(3/100); if(i == nbFrame, i = 0;); );
Is there another way to do it? Because this does not work independently of the main calculation script.
Is there a way to custom the busy light()?
Thanks
Regards,
Guillaume
Guillaume
Re: Custom Busy Light( )?
Hello @guillaumebugnon ,
I think another possible way to show an animated gif in a new window, you can use Web Browser Box() function.
Here is a sample script to do this. In this script, you need to create html file, which is embedded gif animation.
nw = New Window( "Example",
	<<Show Menu( 0 ),
	<<show toolbars( 0 ),
	V List Box( Text Box( "Please Wait!" ), Spacer Box( size( 20, 20 ) ), wb = Web Browser Box() )
wb << Navigate( "file:///C:/xxxx/xxxx/test.html" );
nw << Set Window Size( 200, 200 );
//test
Wait( 5 );
nw << close window();
Here is an example of an html file.
<!doctype html>
<html>
  <body>
    <div style="text-align: center">
      <img src="./spinner.gif"  width="50" />
    </div>
  </body>
</html>
	<<Show Menu( 0 ),
//test
Wait( 5 );
<!doctype html>
<html>
  <body>
    </div>
  </body>
</html>
Hello @yuichi_katsumur,
That's a very good idea. I'll try that, it should work.
Guillaume
It works !!
Thanks a lot @yuichi_katsumur
Guillaume
