Not sure if your 2D plot it based on points or a formula. If points, you could use graph builder to plot your target value against one dimension in your chart with a data filter to define the 'slice' in the other dimension.
If you are exploring a column formula, then I agree with @Mark_Bailey that the profiler is the easiest approach. Just change the value of one value and see the plot on the other.
Below are scripts for both:
Names default to here(1);
dt = Open("$Sample_data/iris.jmp");
New Column("H1_1", Numeric, "Continuous", Format("Best", 12), Set Property("Notes", "Model NTanH(3)"), Formula(TanH(0.5 * ((-3.50407799736543) + -1.69201212624413 * :Sepal length + 4.45798369366822 * :Sepal width))), Set Property("Intermediate", 1));
New Column("H1_2", Numeric, "Continuous", Format("Best", 12), Set Property("Notes", "Model NTanH(3)"), Formula(TanH(0.5 * ((-4.34695576142641) + 0.578814453314083 * :Sepal length + -0.387699136913814 * :Sepal width))), Set Property("Intermediate", 1));
New Column("H1_3", Numeric, "Continuous", Format("Best", 12), Set Property("Notes", "Model NTanH(3)"), Formula(TanH(0.5 * ((-14.9199578715582) + 8.0363609653296 * :Sepal length + -9.32672254743267 * :Sepal width))), Set Property("Intermediate", 1));
New Column("Predicted Petal length", Numeric, "Continuous", Format("Best", 12), Set Property("Notes", "Model NTanH(3)"), Formula(9.72824082889675 + 0.825393378043811 * :H1_1 + 8.38378988028562 * :H1_2 + 1.62929374850912 * :H1_3), Set Property("Predicting", {:Petal length, Creator("Neural")}));
New Window("Plotting points",
H List Box(
Graph Builder(
Size( 522, 456 ),
Variables( X( :Sepal length ), Y( :Petal length ) ),
Elements( Points( X, Y, Legend( 295 ) ), Line( X, Y, Legend( 297 ) ) ),
Local Data Filter(
Add Filter(
columns( :Sepal width ),
Where( :Sepal width >= 2.9 & :Sepal width <= 3.1 )
Contour Plot(
X( :Sepal width, :Sepal length ),
Y( :Petal length ),
Show Data Points( 0 ),
Fill Areas( 0 ),
Label Contours( 0 ),
Transform( "Range Normalized" ),
Specify Contours( Min( 2 ), Max( 6 ), N( 5 ) ),
Dispatch(
"1",
ScaleBox,
{Add Ref Line(
{2.9, 3.1},
"Solid",
"Medium Dark Magenta",
"Slice",
1,
0.25
//Profiler
Profiler(
Y( :Predicted Petal length ),
Profiler(
1,
Term Value(
Sepal length( 6.302, Lock( 0 ), Show( 1 ) ),
Sepal width( 3.125, Lock( 0 ), Show( 1 ) )
Expand,
Dispatch(
{"Prediction Profiler"},
"Profiler",
FrameBox,
{Frame Size( 320, 260 )}
Dispatch(
"Profiler",
FrameBox( 3 ),
Updated: added column formulas for prediction column to script.
