ENTHU
Creating webpage for html output
How do I create webpage where I can post jsl html output so that people without jmp can view  html?
Re: Creating webpage for html output
Go to the Display Output you want to make into a webpage, and select
File==>Save As
And when the Save window pops up, go to the File Type down arrow, and select HTML or Interactive HTML, and then set the path and the name and then save the output
Jim's answer is correct, but if you're using JMP on a Mac computer, you would start with File==>Export instead of File==>Save As.
To use JSL to Save a report as Interactive HTML, use:
report << Save Interactive HTML( "C:\Bivariate.html" );
For more information, please see one of these JMP Discovery papers:
Sharing Interactive Web Reports in JMP 13
Sharing Interactive Web Reports in JMP14
If you already have JMP 14.2, you might want to use JMP Public to share your html output.
Please see: Posting to JMP Public
~John
ENTHU
Thanks for the response.Sorry that I did not explain my question correctly.I am already using save HTML option. But I would like to have a webpage where all my jmp reports can be posted.This way I should just be able to give a weblink to everyone who wishes to see the report.
Is this capability available in jmp or do I have to use .net?
You can do this with JMP 14.2 using JMP Public to hold all your reports.
With earlier versions of JMP, you can create your own site with a web hosting service, upload your html files, and provide links to them. There are many services to choose from, but not all will support serving up whole web pages.  In the second JMP Discovery paper I listed, we discuss a JMP user who ran into this issue and how he got around the limitation. There's a link at the bottom of that paper to a JMP Community discussion leading up to the solution.
