LarryLowry
Creating ppt with multiple graphs per slide with JSL
In the past, I have created PowerPoints by manually copying and pasting individual graphs from JMP to PowerPoint. Is there a way to script this so that JMP automatically does this for me? I have figured out how to script one graph per slide but it is not what I am looking for. An example would be, from my data, I create 16 different contour plots. I would like to make a script that will put these contour plots on 2 slides with 8 contour plots per slide.
Re: Creating ppt with multiple graphs per slide with JSL
There are many previous entries on this. I suggest you search the site for them
One reference is:
How to save journal as PPT (2 graphs per slide) using JSL
One reference is:
