madhu
Creating a dynamic bubble plot in JMP Pro 18
Can anyone guide me through the steps to create a dynamic bubble plot in JMP Pro 18, similar to the Katrina Data – Bubble Plot of LAT by LON example available in the JMP Database? I’ve developed a comparable dataset titled Hurricane_Hypo_1 (attached), and although I’ve reviewed the guidelines under Bubble Plots. I’m still unsure how to replicate that type of visualisation using my own data.
Re: Creating a dynamic bubble plot in JMP Pro 18
What issues are you having with the dynamic bubble plot?
Create bubble plot using Katrina data and go to
This will open the Bubble Plot launcher and you can see how columns have been set. Also, verify your columns are similar data types and modelling types (your data is character/nominal no numeric/continuous). That bubble plot has also background map set and most likely LAT / LON formats changed,  Essential Graphing > Maps > Additional Examples of Creating Maps > Example of Adding a Background M...
There is also example of dynamic bubble plot  Essential Graphing > Bubble Plots > Example of a Dynamic Bubble Plot .
