Jackie_
Creating a UI to input a file using button box and generating graph in the same window
I'm trying to create a UI to input a JMP file using button box and generating graph in the same window in Vlistbox.
Here's me code: It gives me an error because the data table isn't selected. Any suggestions?
New Window( "",
	modal,
	Button Box( " Click to Open", dt = Open( "$SAMPLE_DATA/Big Class.jmp" ) ),
	V List Box(
		obj = dt << Graph Builder(
			Variables( X( :Sex ), Y( :Height ), Group X( :Age ) ),
			Elements( Box Plot( X, Y ) )
ErraticAttack
Re: Creating a UI to input a file using button box and generating graph in the same window
You need to defer filling in the VLB until the button is pressed.  Also, you can use the Platform() function to help with table scoping (speaking of scoping, you can use the window pseudo-namespace to help with scoping)
New Window( "Test",
	Modal
		window:dt = Open( "$SAMPLE_DATA/Big Class.jmp" );
		window:vlb << Append(
			Platform( window:dt,
				window:obj = window:dt << Graph Builder(
	window:vlb = V List Box()
Jordan
ErraticAttack
New Window( "Test",
	Modal
Jordan
