New to JMP? Let the Data Analysis Director guide you through selecting an analysis task, an analysis goal, and a data type. Available now in the JMP Marketplace!
I have inspected a wafer with 9 units on it. It is a 3X3 array of units (9 samples or parts) on wafer. I have their Column Row number and pass fail results in a table. A sample table is attached. I was wondering if it is possible to create a pass fail map graph (attached) where pass units are highlighted in green and failed units are highlighted in red. I would like to create a JSL script to do this. Any guidance will be highly appreciated.
If I understand you correctly, you attached an example of the desired plot. You can click the red triangle at the top right of Graph Builder and select Save Script > To Script Window. This script can be used as it or modified as needed.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '252464' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '252464') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '252464') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
