Fatemeh_2020
How can I create a Power Curve in JMP?
Hello!
Please, explain how I can create a Power Curve in JMP?
I want to graph the power curve for 7 values of mean and I know the null hypothesis.
Re: How can I create a Power Curve in JMP?
Use the power calculators in JMP. Select DOE > Design Diagnostics > Sample Size and Power. Click the button that corresponds to the test that you will use.
See Help > Books > Design of Experiments Guide > Prospective Sample Size and Power chapter for a complete description and worked examples..
Fatemeh_2020
Thank you so much!
