YotamS1
Create multiple charts with different reference lines
I would like to accomplish the following task using JSL code:
I have an example file (attached) with 4 columns: date (numeric), y_val (numeric), limit (numeric), group (character).
The "group" column contains 3 distinct values: A,B,C
Each group has a unique value in "limit" column. For example, all group A rows have a value of 67 in the "limit" column.
The task:
1. I would like to create 3 charts (one for each group), each of them in different tab.
2. The tabs names should be according to groups. So A,B,C.
3. Each chart (Y by X) should have "date" in X axis, "y_val" in Y axis, and value of "limit" as a reference line on the y axis (that matches the specific group).
I have attached an example data table, as well as simple JSL script that gives the output I want.
However, the code has 3 drawbacks:
1. I specified the reference line values manually, instead of reading them from "limit" column.
2. I named the tabs "A","B","C" manually, instead of reading them from "group" column.
3. I manually created 3 tabs, instead of automatically counting how many tabs I need (according to the number of distinct values in "group" column).
I would like the solution to address the drawbacks above, as it should generalize for any number of groups (for example A-Z, which means 26 groups and 26 different values for reference lines).
Any help would be appreciated.
Thanks
Re: Create multiple charts with different reference lines
How did you modify For Each? It should be changed to something like
For(idx = 1, idx <= N Items(groups), idx++,
	group = groups[idx];
Full script
View more...
dt = Open("$DOWNLOADS/example.jmp");
// get groups and limits
Summarize(dt, groups = By(:group), limits = Min(:limit));
nw = New Window("Trends", << journal,
	tb = Tab Box()
//For Each({group, idx}, groups,
	biv_expr = EvalExpr(
		temp_biv = dt << Bivariate(
			Y( :y_val ),
			X( :date ),
			Automatic Recalc( 1 ),
			Where(:group == Expr(group))
		rbiv = temp_biv << report;
		axisbox = rbiv[axis box(1)];
		axisbox << Add Ref Line(
			limits[idx], "Solid", "Black", "", 1
	tb << Add(group, V List Box(biv_expr));
tb << Set Selected(1);
Below is one possible example script. If you don't have JMP16+ you will have to change For Each to For loop.
	tb = Tab Box()
			Y( :y_val ),
			X( :date ),
YotamS1
Thank you for the quick response!
I have JMP 14.
I copied your script and changed the "For Each" to "For", but got an empty window after running (no error messages).
Maybe there's something else that needs to be changed?
Full script
View more...
	tb = Tab Box()
			Y( :y_val ),
			X( :date ),
YotamS1
Great, now it works!
Thanks a lot!
