Dukowitz62
Create m/y column from separate character month and year columns
How do I create a date column with format yyyymm or m/y from two character columns entitled Month and Year?  This data is imported from city water billing system as a text file. See attached example.  I know how to concatenate the columns into another character column, but we will need the output column formatted as a date column to perform frequency calculations.
Re: Create m/y column from separate character month and year columns
JMP stores dates as the number of seconds since January 1, 1904. As such, you must supply a day, you just don't need to display it or use it.
I noticed that you had your month and year columns listed as character strings. They probably should be numeric, but this formula will work with them as character string:
Notice that the Date MDY function requires the numeric Month, numeric Day, and numeric Year values to be entered. I used the first day of each month as the default. Then use the column info on this new column to set the format to be numeric, and the format of m/y. I have attached the new table with the formula in it.
Dan Obermiller
Dan Obermiller
Dukowitz62
That makes perfect sense.  Thank you for your response.
