AsymptoticCos
Create a new concatenated table based on two existing tables
Hi, I have input table A that looks like this,
Input Table B looks like this,
I want to create an output table C: that should look like this,
I can do this manually. Is there a way to script this?
Level XIII
Re: Create a new concatenated table based on two existing tables
Tables/Join can do the Job - use as match specification Cartesian Join:
The column names in both tables should differ from each other, otherwise the name of the source table will be added to the column name.
dt1 = New Table( "dt1",
	Add Rows( 3 ),
	New Column( "Column 1", Character, Set Values( {"A", "B", "C"} ) ),
	New Column( "Column 2",	Set Values( [1, 2, 3] )	),
	New Column( "Column 3",	Set Values( [1, 2, 3] )	)
dt2 = New Table( "dt2",
	Add Rows( 3 ),
	New Column( "Column 4",
		Character,
		Set Values( {"X", "Y", "Z"} )
dt1 << Join(
	With( dt2 ),
	Cartesian Join
Level XIII
	Add Rows( 3 ),
	Add Rows( 3 ),
		Character,
dt1 << Join(
	With( dt2 ),
	Cartesian Join
