Sburel
Create a loop to add column properties to columns that contain a specific header
Being still new with JSL, I'm still struggling with the implementation of certain concepts namely looping.
Any way, I'm trying to create a script which would add to any column in a table in which the header contains "Norm" a number of specific column properties.
dt=current data table();
a = "Norm";
col = dt << get column names( string );
nc = N Items( col );
For( i = 1, i <= nc, i++,
If( Contains( col[i], a ),
col[i]<<Add Column Properties(
	Set Property( "Axis", {Add Ref Line( 200, "Dotted", "Red", "", 2 )} )
Unfortunately, I'm clearly missing something fundamental and the script is not going anywhere.Some guidance would be greatly appreciated.
Thanks
Sebastien
Re: Create a loop to add column properties to columns that contain a specific header
See if this is what you want
dt = Current Data Table();
a = "Norm";
	If( Contains( col[i], a ),show(col[i]);
		column(col[i]) << Set Property( "Axis", Add Ref Line( 200, "Dotted", "Red", "", 2 ) )
a = "Norm";
Sburel
Worked like a charm.
Thanks a lot for the very rapid suggestion.
Much appreciated
