  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
JinwookKim
Create a list of candidates from the partition results for mutable variables
I can't understand why this script is not working.
Please helt me to correct my problem. Thanks.
dt = Open("$sample_data\Big Class.jmp");
List = dt << get column name(numeric);
Report = Expr(
	rpt = New Window("Big Class - Decision Tree of sex",
		dt << Partition(
			Y(:sex),
			X(Eval Expr(List)),
			Informative Missing(1),
			SendToReport(Dispatch({}, "Candidates", OutlineBox, {Close(0)}))
	rpt["Partition for sex", "Candidates", Table Box(1)] << Make Into Data Table;
Eval(Eval Expr(Report));
Re: Create a list of candidates from the partition results for mutable variables
Depending on what you are trying to do in the end, here is one option how you could modify the script
numcols = dt << get column names(numeric, string);
	dt << Partition(
		Y(:sex),
		X(Eval(numcols)),
dt_candidates = rpt["Partition for sex", "Candidates", Table Box(1)] << Make Into Data Table;
is incorrect.  It needs to be
List = dt << get column names(numeric);
mmarchandFSLR
JinwookKim
It works greatly. Thanks a lot...!
