Deimns287
Create a Column by getting a user input
//Assign Data Table + Delete Column Flag if it already there
dt=current data table();
//Create new window to get data from user
filter="";
nw=New Window("Flag Creation",
	border box(top(50),bottom(100),left(50),right(100)),
	H Center Box(Text Box("Input a single Conditon Bin to Flag")),
	Text Box("Condition:"),fb=Text Edit Box("bbb"),
	Button box("Run",
		filter = fb << get text(),
		dt<<New Column( "Flag",
			Numeric,
			"Continuous",
			Format( "Best", 12 ),
			Formula( filter))
I am a new JMP user. I want to create a column with the value from the user input. However, I got trouble getting the value.
There are 3 concerns:
  • How can I get the user input and create new column by it? The script cannot run or return any data.
  • I try to put create new column outside of New Window command. It instantly create the new columns without carrying any user input into it. How can I solve it? (since I think that JSL will execute the script line by line.
Thanks.
Re: Create a Column by getting a user input
It might be enough if you just change the "," to ";" after your filter = fb << get text(); line
dt = Current Data Table();
filter = "";
nw = New Window("Flag Creation",
	Border Box(top(50), bottom(100), Left(50), Right(100)),
	fb = Text Edit Box("bbb"),
	Button Box("Run",
		dt << New Column("Flag", Numeric, "Continuous", Format("Best", 12), Formula(filter))
If you want to prevent JMP from continuing script execution when window is open, you can use modal windows for that. Construct a Modal Window (jmp.com)
