Create Levey Jennings Chart
Hello all I am new to JMP and am using JMP 16. I have been using R and Excel for most my work and unfortunately lost a recording of how to do this via JMP the correct way. I need to make IMR  and Levey Jennings charts for each attribute, but again I am unfamiliar with the Process. I have attached a picture of my data, and a screenshot of what I did via excel of the acidic Result display name for illustration. I essentially need to create it so the Y Axis is Raw Number and the X axis is batch name and the data being used for each graph is Result Display Name Thanks!
Re: Create Levey Jennings Chart
Welcome to the Discussion Community,
Both the IMR and the Levey Jennings charts are reachable through the
     Help=>Statistics Index
Or you can just go to
     Analyze=>Quality and Process=>Control Charts=>IMR Control Chart
or
     Analyze=>Quality and Process=>Control Charts=>Levey Jennings Control Chart
Select Raw Number as the Y axis and Batch Name as the Sample Label/Subgroup
I strongly suggest that you take the time to read the Discovering JMP document available under the Help pull down menu
or
Appreciate it. There wasn't much online that helped!
