ileshem
Create HTML table with hyperlinks
I have a data table, one of the column values has values with hyperlink, I used "event handler" to create it.
I am trying to export it to an Interactive HTML report but when I do, I loose the hyperlink and get only the values.
Is there any way to get HTML with working hyperlinks?
jrnl=dt<<journal;
zippy=current journal();
zippy<<Save Interactive HTML ("\\Temp\Tasks.HTML");
Re: Create HTML table with hyperlinks
Maybe journal breaks them as this seems to work (using JMP16)
//Making a clickable link show up in a formula column
dt = New Table("Example",
	Add Rows(2),
	New Column("URL",
		"Character",
		"Nominal",
		Formula("https://www.jmp.com/" || :Page),
		Set Property(
			"Event Handler",
			Event Handler(Click(JSL Quote( Function( {dt, col, row}, Web( dt:col[row] ) ) )))
	New Column("Page",
		"Character",
		"Nominal",
		Set Values({"support/knowledge_base.shtml", "en_us/about.html"})
(dt << get as report) << Save Interactive HTML("$DOWNLOADS/test.html");
Web("$DOWNLOADS/test.html");
other method which might not be necessary anymore Insert Hyperlink in Text in the cells
	Add Rows(2),
	New Column("URL",
		"Character",
		"Nominal",
		Set Property(
			"Event Handler",
	New Column("Page",
		"Character",
		"Nominal",
ileshem
Thank you. It doesn't seems to work on JMP14, I will try it tomorrow on JMP16.
