取消
显示结果
显示  仅  | 搜索替代
您的意思是:
选择语言 隐藏翻译栏
Dennis1
Count in a script
I need some assistance with adding a count in a script to a new column where it counts the number of rows from n=1 to n= m (based on size of size of text file). Any thoughts / comments greatly appreciated.
Cheers,
Dennis
1 个已接受解答
已接受的解答
Re: Count in a script
The examples I listed before are assuming that you were adding the columns to an already existing data table.  If you are creating a data table from scratch and it does not have any rows defined for it, one needs to use the
dt << add rows(100);
to create empty rows, before one can place values in the cells.
Here is a complete example
names default to here(1);
dt=new table("Example");
dt << new column( "Counter using a For Loop" );
For( i=1, i<= N Rows(dt), i++,
	dt:Counter using a For Loop[i] = i;
在原帖中查看解决方案
7 条回复7
I am not sure if I really understand what you want, but if it is a simple sequence number you can easily do that multiple ways.
First, interactively.  Once you create the new column, simply go to the Col Info for the new column and click on the Missing/Empty down arrow and select "Sequence Data".  I will place into the new column a number from 1 to n.
Second, you can use a formula in a new column.  Just create the new column, anduse the below formula to generate a sequence number for each row.
Row()
Dennis1
Sorry about not being clear. Is there a way to add the count into a script?
Are either of these examples any help?
dt = current data table();
dt << new column( "RowNum", format( Row() ) );
Dennis1
Thanks for the suggestion.
I am trying to get it to work, but it still does not generation a column
with number 1,2,3,....etc.
I will keep trying.
Cheers,
Dennis1
Thank you, that's awesome! I got it to work.
I just have one more question. If I don't know the exact number of rows
generated (due to text file size variation), is there a way to read the
text file and have the exact rows for the counter?
Dennis1
Thanks for that, works great!
Much appreciated.
Cheers,
推荐文章
