ILoveJMP
Couldn't install JMP Excel Add-in on Snapdragon X Elite laptop for both JMP17 and 18
Was able to install and run both JMP17 and JMP18 on Snapdragon X Elite laptop. However, having issue installing JMP Excel add-in for both. The installation stalled at the following step (https://community.jmp.com/t5/JMP-Knowledge-Base/How-to-install-or-re-install-the-Excel-Add-in-for-JM...
  • The installation options box now appears. Find the entry for the Excel Add-In and uncheck it. Click OK and follow the process as instructed.
Re: Couldn't install JMP Excel Add-in on Snapdragon X Elite laptop for both JMP17 and 18
It sounds like you should contact JMP Support
     [email protected]
ILoveJMP
Thanks Jim! Just sent an email to [email protected]
