ENTHU
Converting alphabet to digits
I have a column that contains vaalues like M N , Y Z etc.
I need to remove the space in between,swap the characters and convert last alphabet to digit.
That means -
input : M N
output : N13
How can I do this?
Re: Converting alphabet to digits
check to see if you only have 1 word and if so, then change the response
if(word(2, :Column 1, " ") == "",
     do what you want if only one letter,
    Word( 1, :Column 1, " " ) || Char(
	Hex To Number( Hex( Word( 2, :Column 1, " " ) ) ) - 64
This will work for your displayed case....but I don't know if it is complete enough.
alphabet="ABCDEFGHIJKLMNOPQRSTUVWXYZ";
word(2,:targetvariable," ") || Char( contains( alphabet, word(1,:targetvariable," ")))
  This is a formula that can be used for a formula for a new column.
Thierry_S
Try the following Formula (copy - paste in the Formula Editor)
Here is a snapshot of what the table will look like
Thierry R. Sornasse
ENTHU
Thanks for the response.For M N , the expected output is N13. I was able to change the Word function and get this working. There can be cases when column 1 has only one alphabet like "A". In this case i need to print A0 in column 2. How can I extend the code to do this?
