shasheminassab
Convert time from character to continous
I have a "Time" column in my dataset and am attempting to convert it to Continuous data type. I am using the "Set Format Pattern" in JMP 16 and everything looks OK except for the timestamps at midnight. This is because the midnight time (00:00:00) in the original dataset is missing. See the attached picture. Any suggestions on how to fix it?
Re: Convert time from character to continous
@shasheminassab
I would just pass through the Time(Character) column and add " 00:00:00" if the hours, minutes, seconds do not appear
Something like this should work
For Each Row(
	If( Contains( :"Time(Character)"n, ":" ) == 0,
		:"Time(Character)"n = :"Time(Character)"n || " 00:00:00"
aliegner1
not an answer, but I came here to post something very similar
I've got a date timestamp coming in as Character>Nominal in this wierd timezone format that I can't figure out how to convert to a proper date-timestamp.
2021-05-05T15:04:52.000000Z
changing the properties results in an empty column. How to script this?
@aliegner1  That time format is most likely ISO 8601 time format with milliseconds.I think JMP will recognize it correctly if you were to just remove .000000Z from the end (if you don't need it).
One way to get rid of .000000Z would be with formula like:
Word(1, :wafer_process_start_time, ".")
I would most likely start by fixing the wrong data. If there are only couple of wrong values you could use recode or you could write some formula to do the fixing for you. Below is one option that could work:
dt = New Table("Untitled 3",
	Add Rows(5),
	Compress File When Saved(1),
	New Column("datechar",
		Character,
		"None",
		Set Values(
			{"13.05.2021 20:00:00", "13.05.2021 21:00:00", "13.05.2021 22:00:00",
			"13.05.2021 23:00:00", "14.05.2021", "14.05.2021 01:00:00"}
wait(1);
Column(dt, "datechar") << Set Each Value(If(Length(:datechar) <= Length("14.05.2021"),
	:datechar || " 00:00:00", :datechar));
@shasheminassab
For Each Row(
shasheminassab
Thanks Jim. Very helpful as always.
Sina
