I have some data that I want to display in a specific way with some box plots and can't figure out how to get the result I'm looking for. I have measurements of a parameter at four locations, let's say Location 1, Location 2, and Location 3. The measurements are done on three different types of parts, let's say A, B, C. I have a huge population of data from parts of Type A at Location 1 and Location 2. I have a very small amount of data for parts of Type B and C (one of each), at all three locations 1, 2, 3. Here is what I want to do:
- Show only boxes for Type A at Location 1 and Location 2
- Show only points for Type B and C, at all Locations
So in JMP, I have three columns: Data, Location, and Type. Using Graph Builder, I set Data to Y, Location to X grouping, and Type to Color. I enabled points and box plot, and set the transparency of the points for Type A to 0. This has me 99% of the way there. Now I'm just stuck on how to remove the box at Location 3.
Bonus points: In this case it's not a big deal, but ideally I would like the boxes to not be calculated using the B and C data. The only way I can think to do that is to split A off into its own column but then it overall seems more cumbersome.
![jmp_boxplot.png jmp_boxplot.png](https://community.jmp.com/t5/image/serverpage/image-id/63043i3CE4465F30B973DF/image-size/large?v=v2&px=999)
