Neo
Neo
Continue or abort based on user input.
Below is a small script to check user input (below) which I plan to place in another main script. I want to proceed with the rest of the main script if the user selects OK and abort if the user clicks Cancel in the user input script. How to achieve this?.
mywin1 = new window("YOU HAVE SELECTED:", << modal,
      //ID = "part123";
      //flavour = "Red";
      //TestYear = "2021";
      //LimFileName  = "EVTeg";
      text box("Wafer ID: "||ID||" \!nProduct Type: "||flavour||" \!nTest year: "||TestYear||" \!nLimts File: "||LimFileName||" \!nDo you wish to continue?"),
      button box("Yes", which_button = "OK"),
      button box("No", which_button = "Cancel"),
The commented lines were just to test this piece of code. These would be supplied from the main script above the test user input script.
When it's too good to be true, it's neither
Re: Continue or abort based on user input.
One option would be to use <<return result with <<modal and then check the value of mywin1["Button"] after modal is closed
ID = "part123";
flavour = "Red";
TestYear = "2021";
mywin1 = New Window("YOU HAVE SELECTED:",
	<<modal,
	<<Return Result,
	Text Box(
		"Wafer ID: " || ID || " \!nProduct Type: " || flavour || " \!nTest year: " || TestYear ||
		" \!nLimts File: " || LimFileName || " \!nDo you wish to continue?"
	Button Box("Yes", which_button = "OK"),
	Button Box("No", which_button = "Cancel"),
show(mywin1); //debug print
If(mywin1["Button"] != 1,
	Show("cancel");
	throw("cancel pressed");
	//stop();
Show("ok");
Show("continue execution");
Also <<On validate(expr) and << On Close(expr) might be helpful
ID = "part123";
flavour = "Red";
TestYear = "2021";
	<<modal,
	<<Return Result,
	Text Box(
	Show("cancel");
	//stop();
Show("ok");
Neo
Neo
@jthi
Thanks. This seems to be working.
While I test the actual code I have one more question (not related to the OP). How do I make the following text bold?
YOU HAVE SELETED:
Wafer ID:
Product Type:
Test year:
Limts File:
Use the Set Font Style message....see below
ID = "part123";
flavour = "Red";
TestYear = "2021";
	<<modal,
	<<Return Result,
	tb = Text Box(
	tb << set font style("bold");
	Show("cancel");
	//stop();
Show("ok");
All of the messages that can be sent to the various objects are defined in the Scripting Index.
