NickT
Constrained variables query
Can anyone advise a simple way to indicate that either a factor or an effect is constrained within limits ?  Examples would include numbers expressed as %'s which must therefore lie between 0 & 100, such as Purity or the Yield of a reaction.  This would be especially useful if it can be applied to a data table column, for example, rather than needing to be built into a custom design, thus enabling the simpler methods of fitting models such as Full Factorial or Response Surface
Thanks
Nick
Re: Constrained variables query
Check out the column property, "Response Limits".
     Help
and then search on Response Limits
NickT
Thanks for the suggestion.  I have taken a look at the options available from the drop-down menus in the Column Properties field (there are a lot of them !).  Also I have referred to the Help.  At least from the latter perspective the only clear instruction (to me) is that this is a way of setting the desireability of an outcome in terms of High and Low values.  So, whilst this might reject an outcome of -1 or +101 as being unfit to meet the targets set, it would not actually influence the modelling process that could generate such numbers,  I am no statistician, but I can remember from courses I took long ago that there are "special" ways of treating variables which are "bounded" - so whilst for example you might expect to find a Gaussian distribution of values either side of (for example) a solution being made up with a target of 50% concentration, if the target is changed to 100%, the distribution curve would look like one half of the normal bell curve, as its impossible (other than by measurement error) to get a value above 100%.
There may be something yet to be found in JMP on this matter, but frankly I don't find the Help very helpful - its good to have the Community as an alternative, so thanks again for pointing out this option.
Or maybe the Range Check column property?
NickT
Thanks for the suggestion, but according to the Help entry for Range Check, this simply alerts to (or excludes) numbers that lie outside a predefined range for data entry  This is fine for alerting to a typo or an excel formula error (for example) but does not reflect the position from a statistical analysis perspective.  ie the model will still be constructed in terms of predictions below 0 or above 100 (% purity), even though such values these are meaningless numbers, nd cannot be attained in practice (other than by measurement uncertainty) - just as length is a continuous variable, except that its impossible to have a negative length.
