gallardet
Connection error while attempting to connect to WMS server
In JMP 9.0.1 I get this message when I try to embed a map from a WMS server:
"Connection error while attempting to connect to WMS server"
Is there a solution?
Thanks
8 REPLIES 8
Re: Connection error while attempting to connect to WMS server
Either the URL is incorrect or perhaps authentication is required for your chosen service. What are you using for URL and Layer?
gallardet
Dear Mark the connection URL is: https://geoserveis.icgc.cat/icc_mapesbase/wms/service?
The name of the layer is: orto25m
I got the same error message as you did. I went to the service site and found this URL, https://geoserveis.icgc.cat/icc_mapesbase/wms/service?, which looks the same as your URL, but I do not get the same error any more. I used the same layer code as you did. I now get a new error, "Unknown image type while attempting to retrieve maps from WMS server."
I am no expert in these map services. It should work with a valid URL and layer code. Perhaps you can ask this service for technical support.
Something like this:
Graph Builder(
	Size( 1593, 909 ),
	Elements( Points( X, Y, Legend( 1 ) ), Smoother( X, Y, Legend( 2 ) ) ),
		Dispatch(
			"height",
			ScaleBox,
			{Scale( "Geodesic" ), Format( "Fixed Dec", 12, 3 ),
			Min( 1.31223015389874 ), Max( 1.40750524670734 ), Inc( 0.01 ),
			Minor Ticks( 1 )}
		Dispatch(
			"weight",
			ScaleBox,
			Min( 41.6982769662546 ), Max( 41.7501872243177 ), Inc( 0.002 ),
			Minor Ticks( 1 )}
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Background Map(
				Images(
					"Web Map Service",
					"https://geoserveis.icgc.cat/icc_fonstopografic/wms/service?",
					"mtc25msg"
				Boundaries( "World" )
Information around here: https://www.icgc.cat/es/Administracion-y-empresa/Servicios/Servicios-en-linea-Geoservicios/WMS-y-tes...
Note this server seems to be for a tiny area on the face of the earth, if you are not looking in the right place, you get nothing.
Yes, I used big class height and weight for longitude and latitude.
gallardet
Benvolgut Craige,
I don't know where in the world you live but I know very well where I live. A tiny area, a small triangle in the northwestern Mediterranean, a country with almost eight million inhabitants, half a million less than Switzerland. With Constitutions since 1283 and which were abolished by military victory of Philip V of Castile in 1714. Catalonia is trying to regain its independence by democratic means, but neither Spain nor its government is willing to do so. They prefer the rulings of the right-wing supreme court against the Catalan leaders. Dare you say that Switzerland is a tiny area.
The "Institut Cartogràfic i Geològic de Catalunya" has a public WMS where you can get different layers of the map of Catalonia. With JMP 14 on Windows it connects and downloads the layer, with JMP 9 on Mac it does not.
I attach screenshots made with JMP 14 to verify it.
Translated with www.DeepL.com/Translator (free version)
gallardet
Thanks
Sorry, that was thoughtless on my part. I'm glad more recent versions of JMP work for you!
gallardet
I appreciate your reply and your interest in helping me.
Thanks,
Manel
