Feli
Connecting table variable to slider box
I have a table variable A that is connected to some formulas in my data table.
dt = currentdatatable();
dt << Set Table Variable( "A", 1 );
I want to build an application using the Application Builder where I move a slider using the Slider Box and this updates my table variable A in the data table, i.e. if the slider is changed to 2, A is updated to 2 in the data table.
How could I connect those two? I know I can update a table variable using JSL:
dt << Set Table Variable( "A"), 2 );
Is there a way of combining the running of a short script that updates the table variable when dragging the slider? I tried putting in the script in the Move-> Edit scripts under the Properties Window of the slider box
dt << Set Table Variable("A"), mySlider );
with Variable Name mySlider, but when running the Application, I get the error image.png
when moving the slider, so I must be doing something wrong.
Any hints?
Re: Connecting table variable to slider box
You have to use the Slider Box object in a window. The box has a script that is evaluated whenever the slider is changed. Use this script to change the table variable. Also, you can use the << Set Table Variable message, or because table variables behave like columns in an expression (formula, script), you can simply and directly assign the new value.
This example should show you how to use a Slider box script.
Names Default to Here( 1 );
dt << New Table Variable( "Parameter", 1 );
New Window( "Sliding",
	Outline Box( "Control",
		Slider Box( 1, 10, p,
			dt:Parameter = p;
			dt:Parameter = p;
Feli
That helped indeed! Thank you.
