Confidence intervals of all quantiles in survival analysis
Nov 18, 2025 04:09 AM(1701 views)
Hi In survival analysis the confidence intervals are given for the median time, and also suvival time is given at 25% and 75% survival but here no confidence intervals are given. Where can I obtain them ?
First, fit a survival distribution model (e.g., Weibull Fit from platform red triangle menu). Then select Estimate Survival Probability or Estimate Time Quantile from the same menu. The new outline will contain the information you want.
The Quantiles outline reports values that are based on the non-parametric estimates from the Kaplan-Myer product-moment method. The other values are parametric estimates based on the fitted distribution model. Different methods or models lead to different estimates.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '913902' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '913902') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '913902') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
