JesperJohansen
Confidence interval limits for REML ANOVA random effects
I am trying to understand how the confidence interval limits for the variance estimates of the random effects REML output is calculated.
In the JMP help it is stated that:
If Unbounded Variance Components is selected, Wald-based confidence intervals are computed. These are valid asymptotically but note that they can be unreliable with small samples.
If Unbounded Variance Components is not selected, meaning that parameters have a lower boundary constraint of zero, a Satterthwaite approximation is used (Satterthwaite 1946).
I am interested in the bounded intervals. However, it is not clear how the Satterthwaite approximation is implemented.
In the example in "Investment Castings.jmp" from the Sample Data Library i can reproduce the confidence interval limits using a proper number of degrees of freedom (see attached file). I need 8*(4-1) = 24 for Residual, which I can understand. But how are the degrees of freedom for the Casting and Total obtained? And where in the REML report can I find them?
BR
Jesper
JesperJohansen
Re: Confidence interval limits for REML ANOVA random effects
Support gave the solution. The degrees of freeedom is calculated as:
2 * (:Var Component / :Std Error) ^ 2
BR
Jesper
JesperJohansen
Can noone answer this?
BR
Jesper
First, in general, SAS often does not provide details about implementation because that information is proprietary.
I do not know the answer to your question. All I found is the same documentation as you. I recommend contacting JMP Technical Support ([email protected]) to see if they can provide the detail you want.
JesperJohansen
thank you Mark
I will try this.
I really hope this is not proprietary. If I cannot understand how a conifdence interval is calculated, I cannot undersatnd exactly how to interpret it.
BR
Jesper
JesperJohansen
BR
Jesper
