JesperJohansen
Confidence and prediction intervals for orthogonal regression?
I can tell that this question was posted back in 2012, but never answered, so here it goes again:
Is there a way to plot confidence and prediction intervals for orthogonal regression in the Bivariate platform. Also I would like to save the interval equations. Both options exist for "Fit line", i.e. OLS linear regression.
If the option does not exist, I would like to request it be implementet.
BR
Jesper
JesperJohansen
Re: Confidence and prediction intervals for orthogonal regression?
Noone from JMP reading this?
BR
Jesper
ian_jmp
Level X
With JMP Pro, you could try bootstrapping:
NamesDefaultToHere(1);
// Sample data
dt = NewTable("Orthogonal Regression",
		NewColumn("x1", Formula(RandomUniform(-1, 1))),
		NewColumn("x2", Formula(RandomUniform(-1, 1))),
		AddRows(50)
// Fit orthogonal
fo = dt << Bivariate(Y( :x2 ), X( :x1 ), Fit Orthogonal( Equal Variances ));
// Bootstrap fitted parameters
dt2 = Report(fo)[TableBox(2)] << Bootstrap(1000);
// Look at the result
dt2 << Distribution(
				Continuous Distribution( Column( :Intercept ) ),
				Continuous Distribution( Column( :Slope ) ),
					Dispatch( {"Intercept"}, "Quantiles", OutlineBox, {Close( 1 )} ),
					Dispatch( {"Intercept"}, "Summary Statistics", OutlineBox, {Close( 1 )} ),
					Dispatch( {"Slope"}, "Quantiles", OutlineBox, {Close( 1 )} ),
					Dispatch( {"Slope"}, "Summary Statistics", OutlineBox, {Close( 1 )} )
JesperJohansen
Alas, I don't have Pro :'-(
BR
Jesper
Hi Ian,
Thank you for this JSL script. However, the script only boostraps estimates of slope and intercept. I was curious how would I then go about estimating prediction interval in deming regression using this output? I would appreciate any assistance.
Thank you
