JMPUser9
Conditional Formula
I am trying to add a column formula that is conditional to other columns. I have data where “Results” Column is stacked by “Subject” and “Product” with multiple values over “Time”. I’m trying to calculate the baseline for each value in “Results” so that:
New Column = "Results" – ["Results" value where Time=(1) for that particular Subject/Product combination]
Thank you
Re: Conditional Formula
Sometimes it's  easier to attack problems like this in several steps, rather than writing complex jsl for a column formula. Here's an approach that uses "Subset" to extract the Time=-5 rows, joins them back onto the original data table with "Update", and then performs a simple subtraction in a column formula. If you're running JMP 17, workflows are a great way to build and share this kind of thing.
mmarchandTSI
Can you give an example of the data?  That will help with finding a proper solution.
Just a guess as there is no data to test this with
:Result - Col Min(If(:Time == 1, :Result, .), :Group);
Edit:
Updated formula after we received sample data
:Results - Col Min(If(:Time == -5, :Results, .), :Subject, :Product)
If your data are sorted by Subject, Product, Time then this example will work
dt:age << set name( "Subject" );
dt:sex << set name( "Product" );
dt:weight << set name( "Results" );
dt << New Column( "baseline",
	formula(
		If( Row() == 1,
			valueTime1 = :Results,
			If( :Subject != Lag( :subject ) | :Product != Lag( :product ),
		baseline = :Results - valueTime1;
JMPUser9
I've included sample data. I need to add a new column where the formula takes the Time(-5) Results value for each Subject/Product combination and subtracts that value from each Result in the Subject/Product Combination.
mmarchandTSI
The JSL I came up with isn't too complicated.  I didn't write a formula but a table script.  You could run this whenever you add more data.
OffsetArray = Associative Array();
TimeRows = dt << Get Rows Where( :Time == -5 );
For Each( {val, idx}, TimeRows, OffsetArray[:Subject[val] || :Product[val]] = :Results[val] );
For Each Row( dt, :New Column = :Results - OffsetArray[:Subject || :Product] );
edit
After looking at the table more, I noticed the missing values in some :Results cells.  You should recode those to 0 or alter the script a bit:
For Each( {val, idx}, TimeRows, OffsetArray[:Subject[val] || :Product[val]] = If( !Is Missing( :Results[val] ), :Results[val], 0 ) );
For Each Row( dt, :Results with Offset = :Results - OffsetArray[:Subject || :Product] );
