ladomiqo
Concatenate values in a column
Seems like this should be simple, but I cannot find a clear example. I would like to concatinate the values in columns of a specific name("ROW" and "COL") and create a new column with the result in it. Example below.
ROW COL CELL
5 1 5_1
3 2 3_2
12 -1 12_-1
best shot at code so far:
column("ROW") << Data type(Character);
column("COL") << Data type(Character);
//a = {column("ROW"), column("COL")};
ConExpr = concat items({column("ROW"), column("COL")} , "_");
//Add "CELL" column = concat col(ROW) "_" col(COL)
dt << new column("CELL",Character, "Nominal", Format("Best", 12), formula(eval(Expr(ConExpr))));
my results:
CELL
_
_
Any help in understanding why my code evaluates to that and the correct implementation would be greatly appreciated.
awesome sex cam sites: sex cams , free live sex cams, free cams
mlo1
Re: Concatenate values in a column
I concatenated it the following way. Is this your Goal? Does it help?
Georg
There are several issues in your script,
e.g. you need to put expressions in an "expr()" etc., please see scripting index for further documentation,
and try out.
BR
dt = New Table( "Concatenate",
	Add Rows( 3 ),
	New Column( "ROW", Character, "Nominal", Set Values( {"5", "3", "12"} ) ),
	New Column( "COL", Character, "Nominal", Set Values( {"1", "2", "-1"} ) )
// ConExpr = expr(Concat Items( {Column( "ROW" )[Row()], Column( "COL" )[Row()]}, "_" ));
ConExpr = expr(Concat Items( {:ROW, :COL}, "_" ); );
dt << New Column( "CELL", Character, "Nominal", formula( Name Expr( ConExpr ) ) );
Georg
The New Column syntax can be simplified.
	Add Rows( 3 ),
// Creae new column
dt << New Column( "CELL1", Character,formula(:ROW || "_" || :COL) );
//or
dt << New Column( "CELL2", Character,formula( Concat( :ROW, "_", :COL) ) );
pmroz
Jim's solution is the easiest - no need to overcomplicate things with expr, eval etc.
Georg
sure, simply wanted to stay near to the given example. Eventually there is a more complex environment, that for expr was needed.
Georg
