Brynn
Combining 2 Datasets by Matching 2 Variable Columns
I need to combine 2 large (15k rows) JMP datasets by matching up 2 variables (product_ID and week_ID). In other words, there is a unique record for each product_ID/week_ID combination. Each file contains different attribute columns.
I'm just getting started with JSL so looking for script to get me started on this one task, otherwise I plan on pre-processing using VLOOKUP in excel. Thank you!
data1
product_IDweek_IDtypey1
11a10
12a24
13a33
21a2
22a8
23a14
data 2
product_IDweek_IDtypesub-type1y3
11aR17.9
12aR14.8
13aR15.0
21aD21.7
22aD21.5
23aD20.1
31bR2.2
32bR1.1
33bR1.7
Re: Combining 2 Datasets by Matching 2 Variable Columns
You want to use
     Tables==>Join
If you run the Join interactively, you can open the "Source" entry in the data table that is created from the Join, and it will contain the JSL that was used for the Join.
I entered your two sample data tables into my version of JMP.  They were named Untitled 230 and Untitled 231.  Below is the JSL from the "Source" property in the Joined table
Data Table( "Untitled 231" ) << Join(
	With( Data Table( "Untitled 230" ) ),
	By Matching Columns( :product_ID = :product_ID, :week_ID = :week_ID ),
	Drop multiples( 0, 0 ),
	Include Nonmatches( 1, 1 ),
	Preserve main table order( 1 )
You want to use
     Tables==>Join
Brynn
Thank you! Yes, this works. Can't believe I missed the "join" function in the tables menu.
