Hi all, I am trying to do "save script to journal" with two different plots, it is appending on the journal, the problem is I cannot save the journal itself. Also, in my graph builder plot, why is it prompting to save the file? Please help
Sample script:
biv = dt << Bivariate( invisible, Y( :height ), X( :weight ), By( :sex ) );
biv << Save Script to Journal; //1st
gb = dt << Graph Builder(
Variables( X( :Sex ), Y( :Height ), Group X( :Age ) ),
Elements( Box Plot( X, Y ) )
gb << Save Script to Journal; //2nd which also prompts to save data table file
I am really not sure if this is the correct way to do it, but I wanted to combine this two into only one journal. TIA --using JMP15
