AdirZig
Combine columns which contain specific substring in their name
I am trying to combine only the columns in Data table "dtPatList" which contain the substring "INIT" in their name, but it doesn't work.
I understand that the problem related to the parameter I bolded below. could someone advise for the right way?
Thanks!!
// get the dt cols names
nc = ncols(dtPatList);
col_list = dtPatList << get column names(string);
for (i = nitems(col_list), i > 0, i--,
if (!contains(col_list[i], "INIT")), /// new ps columns
remove from(col_list, i);
//Combine init cols
dtPatList << Combine Columns(
delimiter( "_" ),
Columns(col_list),
Selected Columns are Indicator Columns( 0 ),
Column Name( "INIT_Chain" )
Re: Combine columns which contain specific substring in their name
Try adding Eval() inside Columns:
Columns(Eval(col_list))
You need to place an eval() function around the col_list, to have it expanded in the function Combine Columns execution.
dtPatlist = current data table();
nc = N Cols( dtPatList );
col_list = dtPatList << get column names( string,character );
For( i = N Items( col_list ), i > 0, i--,
	If( !Contains( col_list[i], "INIT" ), /// new ps columns
		Remove From( col_list, i );
//Combine init cols
delimiter( "_" ),
Columns(eval(col_list)),
