Tachyon34
Error "send expects scriptable object..."
HI Everyone, I'm trying a very simple script that is meant to function within a data table, in other words, I have the data table allready and have created a script within it (not sure is that's relevant but thought I'd specify...).
I'm trying to retrieve the spec limits from column7 below and getting this error everytime:
"Send expects scriptable object in access or evaluation of 'Send', Eval Exp(":" || cols[7]) << /*###*/ Get Property ("Spec Limits") /*###*/"
The code I'm using is here:
Names Default to Here(1); //This enables any variables to remain local to the script and not interact with any
                                          //pre-defined jmp environment variables.
Delete Symbols();             //Removes the values of any global variables already defined in the jmp enviroment so that
                                         //they don't override any local variable you may define in your script.
clear log ();
cols = Data Table(1) << Get Column Names( numeric, continuous );
Q = Eval Expr(":" || cols[7]) << Get Property( "Spec limits" );
Re: Error "send expects scriptable object..."
Here is one way of doing what you want using the Column() function.
Names Default To Here( 1 ); //This enables any variables to remain local to the script and not interact with any
Clear Log();
cols = Data Table( 1 ) << Get Column Names( numeric, continuous );
Q = column( char(cols[7])) << Get Property( "Spec limits" );
