JM13
Combinations of a list put into columns
I'm trying to take a list of things and make all possible pairs of combinations appear in a set of two columns.  I currently have a script generated that does permutations (plus repeates of the same value in col a vs col b) but I'm struggling on how to reduce it down to combinations. For example, if the list of things was 1, 2, 3, 4, 5 then I don't need both 1/2 and 2/1, or 1/1.  Below is my script I currently have and I think I'm close, I just need a bit more to get where I need to be. I just need to make this script strictly do the choose 2 combinations of an arbitrary list. This particular example is using 5 things for simplicity.  thanks
New Table( "Test",
	Add Rows( 5 ),
	New Column( "API 10", Numeric, "Continuous", Format( "Best", 15 ), Set Values( [4238939261, 4238939263, 4238939262, 4238939328, 4238939329] ) ),
Test = Data Table( "Test" );
APIs = Test:API 10 << get values;
working = New Table( "TestAPIComb", New Column( "API10" ), New Column( "API102" ), add rows( N Items( APIs ) ^ 2 ) );
APIs2 = Test:API 10 << get values;
theRow = 0;
For( APICNT = 1, APICNT <= N Items( APIs ), APICNT++,
	For( API2CNT = 1, API2CNT <= N Items( APIs2 ), API2CNT++,
		theRow++;
		:API10[theRow] = APIs[APICNT];
		:API102[theRow] = APIs[API2CNT];
9 REPLIES 9
Re: Combinations of a list put into columns
I have added a few lines of code that will eliminate the duplicate combinations.  In addition, I would suggest that you look into
     Tables=>Join
at the Cartesian join capability.
It produces the all possible combinations much faster than JSL code can do it.
New Table( "Test",
	Add Rows( 5 ),
theRow = 0;
		theRow++;
dt = Data Table( "TestAPIcomb" );
// Arange data so order is the same for all rows
For( i = 1, i <= N Rows( dt ), i++,
	If( :API102[i] > :API10[i],
		hold = :API10[i];
		:API10[i] = :API102[i];
		:API102[i] = hold;
// Find the duplicates
dt << Select Duplicate Rows( :API10, :API102 );
// Delete the duplicates
dt << delete rows;
Most likely there are quite many ways of doing this (the cartesian join @txnelson is good starting point). Here is one option using just matrix calculations:
// input list
m = [4238939261, 4238939263, 4238939262, 4238939328, 4238939329];
n_items = N Items(m);
// combination count
comb_count = Summation(i = 1, n_items - 1, i++);
m = Sort Ascending(m);
first_col = [];
second_col = [];
For(i = 2, i <= n_items, i++,
	first_col ||= Repeat(m[i - 1], n_items - i + 1)`;
	second_col ||= m[Index(i, n_items)]`;
dt = New Table("Combinations",
	Add Rows(comb_count),
	New Column("FirstCol", Numeric, Continuous, Values(first_col)),
	New Column("SecondCol", Numeric, Continuous, Values(second_col)),
JM13
Thanks. I looked at what @txnelson suggested and also implemented the cartesian join and it returned 15 results instead of 10. I then just added a simple select condition at the end where if the first column = the second column then I also deleted them. Do either of you know which method is faster in JMP? i'm working with a large dataset and I'll try that matrix method as well but just didn't know if either of you know what should be more efficient.
I don't know which method would work fastest.  My suggestion is to run both of them and see which is fastest.
nthai
Hi @jthi, any ideas if the initial list is string instead of number? Since matrix only works for number data type.
Without much changes you could just use initial list as numbers and then create conversion table to join character values based on those numeric values.
The NChooseK Matrix( ) function is tailor-made for problems like this. It is also reasonably quick, and especially useful for k>2. Check out the code below for an example of 2 things, and 5 things, chosen from a set of 26.
Cheers,
Brady
names default to here(1);
lis = words("abcdefghijklmnopqrstuvwxyz","");
// original example: choose 2
dt = astable( nchoosekMatrix(nitems(lis), 2), << column names({"x", "y"}) );
dt << new column ("first", character, << set values ( lis[dt:x << get values]));
dt << new column ("second", character, << set values ( lis[dt:y << get values]));
dt << delete columns (1::2);
// a more interesting example: choose 5
dt = astable( nchoosekMatrix(nitems(lis), 5), << column names( words("x1,x2,x3,x4,x5",",") ) );
for each ({ i }, 1::5, //i = 1;
	eval (substitute( expr(dt << new column ( "y"||char(i), character, <<set values ( lis[_EX_ << get values]  ) ) ),
								expr(_EX_),
								parse(evalinsert("dt:x^i^"))
dt << delete columns (1::5);
As to performance.
The code below generates the almost 2 million row table of pairs from a set of 2000 in a little under 6 seconds, which is a bit less than half as long as looping took. I don't know whether such performance is suitable for your purposes. Hopefully it is a feasible option for you.
letters = Words( "abcdefghijklmnopqrstuvwxyz", "" );
// create a large list of random strings of length 10. use an AA to remove (unlikely) duplicates
lis = Associative Array( Repeat( {Concat Items( letters[J( 10, 1, Random Integer( 26 ) )], "" )}, 2e3 ) ) << get keys;
t1 = HP Time();
// looping solution
dt = new table( "xx", add rows (2e6), << new column ("X", character), <<new column ("y", character));
n = nitems(lis);
r=0;
for  each ( { i }, 1::(n-1),
	for each( { j }, ( i + 1):: n,
		r++;
		dt[ r, 1] = lis[ i ]; dt[ r, 2 ] = lis [ j ]
t2 = HP Time();
// nChooseK matrix solution
dt = As Table( NChooseK Matrix( N Items( lis ), 2 ), <<column names( {"x", "y"} ) );
dt << New Column( "first", character, <<set values( lis[dt:x << get values] ) );
dt << New Column( "second", character, <<set values( lis[dt:y << get values] ) );
dt << delete columns( 1 :: 2 );
t3 = HP Time();
Print( Eval Insert( "Create table of pairs from loop: ^(t2-t1)/1e6^ seconds." ) );
Print( Eval Insert( "Create table of pairs from nChooseK matrix: ^(t3-t2)/1e6^ seconds." ) );
I should also mention that the examples I used were with strings. If you are using numbers, you can just use straight matrix ops, which are pretty fast... the 2 million row table is generated in 0.3 seconds, and the 26choose5 table in 0.04 seconds.
nums = J(2e3, 1, randominteger(1e9));
t1 = hptime();
astable(shape(nums[nChoosekMatrix( 2e3, 2 )], ., 2));
t2 = hptime();
Print( Eval Insert( "Create table of 2 numbers chosen from 2000: ^(t2-t1)/1e6^ seconds." ) );
// 26 choose 5
nums = J(26, 1, randominteger(1e9));
t3 = hptime();
astable(shape(nums[nChoosekMatrix( 26, 5 )], ., 5));
t4 = hptime();
Print( Eval Insert( "Create table of 5 numbers chosen from 26: ^(t4-t3)/1e6^ seconds." ) );
