FN
FN
Column() vs As Column() vs datable:column vs dt:As name("column")
JSL has several ways to refer to columns. Let's open a data table first.
dt = Open( "$SAMPLE_DATA/Bands data.jmp" );
Now we create a table script that has something like this.
dt = current data table();
print(dt:timestamp == Column(dt, "timestamp"));
// 0
print(Column(dt, "timestamp")==As Column(dt, "timestamp"));
//0
In automated scripts (for example, a graph), when a user changes the name of a column, it seems to adapt the script to the new column name. This failed in custom JSL, with something like Index() appearing.
How one would use all of these methods to make a JSL script robust to column name changes?
Regards,
13 REPLIES 13
FN
FN
Re: Column() vs As Column() vs datable:column vs dt:As name("column")
Could you please include in your answer a reference that explains this bit?
"As Column() "accesses" a column (what this means depends on the case...)."
Best reference (outside of my own experience and lots and lots of trial and error) is from scripting index:
Help pages is other place Column(<dt>, "name", "formatted")  and As Column(name). This also has some information  Scripting Guide > JSL Building Blocks > Rules for Name Resolution > Frequently Asked Questions abou... and  Scripting Guide > Data Tables > Columns > Send Messages to Data Column Objects also Iterate on Rows in a Table , so basically the documentation (especially Scripting Guide).
Level XIII
Nice video tutorial about the differences between column() and as column():
Most Common JSL Mistakes and How to Avoid Them (2020-US-30MP-571)
(starting @ 5:18 min)
with the example
dt << Select Where( Column( colName )[Row()] == 14 );
dt << Select Where( As Column( colName ) == 14 );
Concerning
How about an error handling feature which catches missing-column-events after column name changes - with an option to auto-fix the code.
The idea:
In case of a missing column, instead of showing an error message, JMP could open a window with a column list to pick the correct one.
Then the execution of the code could continue to run - and the source code could be fixed automatically.
Level XIII
Here is the wish :)
catch "missing column" error and provide a selection menu
Should be easy to implement now for JSL Editor - as a similar functionality was just introduced with Jmp 17's new Workflow builder:
https://community.jmp.com/t5/JMP-Wish-List/catch-quot-missing-column-quot-error-and-provide-a-select...
