kschnarrs
Column switcher with Control chart builder
When I hide the control panel on control chart builder, then use column switcher to toggle between control charts, the charts get smaller and smaller until you can no longer see them.
Does anyone know how to fix this?
Re: Column switcher with Control chart builder
Greetings - my news is old, but i did find a reference to this issue in our logs, and it was addressed in JMP 13.1 and later. Anyone encountering this issue using an earlier version of JMP would be well-served to upgrade if possible.
ian_jmp
Level X
With JMP 12.1 (on the Mac), the script below works for me with column switcher. Maybe contact JMP Technical Support giving your version number etc.?
NamesDefaultToHere(1);
dt << Control Chart Builder(
Show Control Panel( 0 ),
Variables( Subgroup( :lot_id ), Y( :NPN1 ) ),
Chart( Position( 1 ) ),
Chart( Position( 2 ) ),
Column Switcher(
:NPN1,
{:NPN1, :PNP1, :PNP2, :NPN2, :PNP3, :IVP1, :PNP4, :NPN3, :IVP2, :NPN4, :SIT1,
:INM1, :INM2, :VPM1, :VPM2, :VPM3, :PMS1, :SNM1, :SPM1, :NPN5, :EP2, :ZD6,
:PBA, :PLG, :CAP, :PBA 2, :PLG 2, :PNP5, :NPN6, :PNP6, :PNP7, :NPN7, :PNP8,
:IVP3, :IVP4, :IVP5, :IVP6, :PNP9, :NPN8, :NPN9, :IVP7, :NPN10, :N_1, :PBA1,
:WPR1, :B10, :PLY10, :VBE210, :VTN210, :VTP210, :SIT2, :SIT3, :INV2, :INV3,
:INV4, :INV5, :FST1, :FST2, :RES1, :RES2, :PNM1, :PPM1, :FNM1, :FPM1, :FST3,
:FST4, :RES3, :RES4, :A1, :B1, :A2N, :A2P, :A2P1, :IVP8, :IVP9, :DE_H1,
:NF_H1, :ESM1, :ESM2, :ESP1, :YFU1, :VPM4, :PBA2, :PBB1, :LYA1, :LYB1, :DEM1,
:DEP1, :NFM1, :PLY1, :VDP1, :VDP2, :SNW1, :RSP2, :PLY2, :RSP1, :VDP3, :PBL1,
:PLG1, :VDP4, :SPW1, :VIA1, :INM3, :VPM5, :VPM6, :INM4, :VPM7, :M1_M1,
:M2_M2, :P1_P1, :E2A1, :E2B1, :NPN11, :IVP10, :PNP10, :INM5, :VPM8, :VPM9,
:INM6, :VPM10, :N2A1, :N2B1, :NM_L1, :P2A1, :P2B1, :PM_L1, :P1, :M1}
Nate_Riordan
Staff (Retired)
Hi kschnarrs,
I've seen this before as well.  The workaround is within what Ian is suggesting.  I've submitted this bug to tech support .  In the meantime I hope you're not afraid to modify the scripting code from the red triangle. The actual fix here is the removal of the size argument that is auto-generated when using the menu's to launch the control chart builder and add the column switcher.
    Size( 534, 454 ),
    Variables( Y( :NPN1 ) ),
    Chart( Position( 1 ), Limits ),
    Column Switcher(
          :NPN1,
          :INM1, :INM2, :VPM1, :VPM2, :VPM3, :PMS1}
          Dispatch(
              "NPN1",
              ScaleBox,
              {Add Ref Line( 104.412948990151, "Solid", "Blue", "LSL", 1 ),
              Add Ref Line( 131.893493064355, "Solid", "Blue", "USL", 1 ),
              Add Ref Line( 118.153221027253, "Solid", "Blue", "Target", 1 )}
