SCWong
Column header naming
I have a datasheet from my workplace with different parameters. Each parameter has different column properties to it such as A, B, C. The parameter is XYZ. However, the column header itself has the title XYZ (A). There seemed to be a way to concatenate the parameter name to the column property value but I'm not sure how to do it. When i double click on the column header, it just shows XYZ, without the column property attached to it.
Thanks!
Re: Column header naming
Either right click on the column header and choose
     Column Properties=>Units
Or click on the * and then on the Units selection to see the actual Column Property
Georg
In addition to the post of @txnelson, it is documented here:
Properties That Control the Display of Columns (jmp.com)
Georg
