Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
shampton82
Column filter above a col list box
Is there a way to get the column filter to show up above a col list box?  Right now I have to use the Column Dialog window to get it which is annoying as it is not as nice to work with as a new window().
Thanks for any advice!
Steve
Re: Column filter above a col list box
Hi @shampton82 - the box shown above is a FilterColSelector:
dt = Open( "$SAMPLE_DATA/PopAgeGroup.jmp" );
New Window( "Filter Col Selector Example",
	Filter Col Selector( width( 250 ) )
The filter field will only show initially if there are more columns than can be shown.
is this what you are talking about
This example comes from the scripting guide for Col List Box()
New Window( "Col List Box Example",
	Col List Box( all, width( 250 ), maxSelected( 1 ) ),
	fontobj = lb = Col List Box()
shampton82
Thanks for the quick reply Jim,
Close but not quite, looking for this:
ErraticAttack
That does not work for JMP14 (the filter is hidden by default for JMP14).  You can manually toggle the filter by using the display tree:
	fcs = Filter Col Selector( width( 250 ) )
fcs[If Box( 1 )] << Set( 1 )
Jordan
I have been using similar method as @ErraticAttack demonstrated to get "col list box" (filter col selector) to easily get filterable column listing.
nw = New Window("",
	flc = Filter Col Selector(dt, nlines(10)),
	((flc << Parent) << Xpath("//IfBox")) << set(1)
 Filter col selector can also be used to create "lazy" filterable list to limit selections from columns, by first creating a data table with column names as the possible options
dt_temp = Open("$SAMPLE_DATA/Big Class.jmp", invisible);
dt_filter = dt_temp << Split(
	output table("filter table"),
	Split By(:name),
	Split(:name),
	Remaining Columns(Drop All),
	Sort by Column Property,
	invisible
Close(dt_temp, no save);
nw = New Window("filterable list", << modal,
	V List Box(
		fcs = Filter Col Selector(dt_filter, nlines(10)),
		((fcs << Parent) << Xpath("//IfBox")) << set(1),
		H List Box(
			Button Box("OK", sel = fcs << Get selected),
			Button Box("Cancel")
Close(dt_filter, no save);
show(sel);
shampton82
Thanks for all the examples!
