user8421
Column Formula for summary value of group based on values in 2 other columns
Hi everyone -
I'm looking for a column formula that would return the following desired column below.  For simplicity in this post each group has 3 rows, but the dataset I currently have has groups with varying numbers of rows.
Any help appreciated!
GroupTimeScoreFirst Time Failed (Desired Column)
A1Pass8
A3Pass8
A8Fail8
B1PassPass
B2PassPass
B6PassPass
C1Pass3
C3Fail3
C7Fail3
gzmorgan0
Re: Column Formula for summary value of group based on values in 2 other columns
@user8421 ,
This is just a fun alternative that uses data table formulas. It will work for unequal Group sizes and if the table is not sorted.
The logic is to find the minimum row number for Fails in each Group. Col Minimum(... , By) is the key. Column statistic functions using the By option are very useful, but often overlooked functions.
Formula for  column "Row First Failed"
Formula for column "Time First Failed". Note if the syntax seems strange, the right-hand formula is Time, then select Subscript from the Row functions and drag column 4, "Row First Failed"
Here is a formula that works with your Example data table.  It has not been tested beyond that, so you may need to make some adjustments
dt = New Table( "Example",
	Add Rows( 9 ),
	New Column( "Group", Character, "Nominal", Set Values( {"A", "A", "A", "B", "B", "B", "C", "C", "C"} ) ),
	New Column( "Time", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [1, 3, 8, 1, 2, 6, 1, 3, 7] ) ),
	New Column( "Score",
		Character,
		"Nominal",
		Set Values( {"Pass", "Fail", "Pass", "Pass", "Pass", "Pass", "Pass", "Fail", "Fail"} )
dt << New Column( "First Time Failed",
	character,
	formula(
		If( Row() == 1,
			check = :Score;
			If( :Group == :Group[2],
				Failed = Char( Col Max( :Time, :Group ), Failed = :Score )
			If( :Group == Lag( :Group ),
				If( :Score == "Fail",
					check = "Fail"
				Failed = Char( Col Max( :Time, :Group ) );
				If( check == "Pass",
					lagGroup = Lag( :Group );
					:First Time Failed[dt << get rows where( :Group == lagGroup )] = "Pass";
				check = :Score;
		failed;
gzmorgan0
@user8421 ,
