kayne
Coloring selective cells
Hi there, how do I color the cells red for values that are lower than the limits? Thanks.
dt = New Table( "Marks",
    Add Rows( 2 ),
    New Column( "Name", Character, Nominal, Set Values( {"Peter", "Leslie"} ) ),
    New Column( "Limits",
        Numeric,
        Continuous,
        Format( "Best", 12 ),
        Set Values( [20, 30] )
    New Column( "Column 1",
        Numeric,
        Continuous,
        Set Values( [10, 15] )
    New Column( "Column 2",
        Numeric,
        Continuous,
        Set Values( [30, 40] )
    New Column( "Column 3",
        Numeric,
        Continuous,
        Set Values( [20, 55] )
    New Column( "Column 4",
        Numeric,
        Continuous,
        Set Values( [53, 24] )
    Set Row States( [0, 1] )
fail = dt << Get Rows Where( :Column 1 < :Limits );
:Column 1 << color cells(Red, fail);
10 REPLIES 10
pmroz
Re: Coloring selective cells
You have to color by column.  This code will do the trick.  The color "73" is a bit lighter than "Yellow"
for (i = 1, i <= ncols(dinout), i++,
	column(dinout, i) << Color Cells( {73, {40}} );
