The answer may depend on what happens next. You can certainly do:
NamesDefaultToHere(1);
// (1) Get some data
dt1 = Open("$SAMPLE_DATA/Big Class.jmp");
// (2) Get summary info into a list and a vector
Summarize(groups = By(:sex), groupMeans = Mean(:height));
// (3) Make a table using the summary info
dt2 = NewTable("Height by Gender",
  NewColumn("Gender", Character, Nominal, Values(groups)),
  NewColumn("Mean Height", Numeric, Continuos, Values(groupMeans))
(see the JSL Scripting Guide for more options with Summarise).
If you need step 3, you may be better using either 'Tables > Summary' or 'Analyse > Tabulate'.
You can also aggregate across any set of rows, so long as you can express what that selection is.
