saitcopuroglu
Col (Sum) function by selecting specific rows
I would like to create a column which calculates another columns mean or sum but I would like to specify the function by :
Let’s say if we select the year the calculation to be occured by "Year" or,
Let’s say col (sum) of NetRevenueWithoutVat by Year or "NetRevenueWithoutVat" by "Month (Stay Date)" or
Col (Sum) functions of specific row numbers...
Would anyone please share his/her knowledge how to do it in scripting or by entering the Col(Sum) function as a formula in a column?
The logic behind it?
Many thanks in adance
16 REPLIES 16
uday_guntupalli
Level VIII
Re: Col (Sum) function by selecting specific rows
Does this solution only work in specific versions of JMP ?
Because I am using JMP 12 and I keep running into this error
dt << select Where(:age ==12);
n = Col Sum(:age,Selected());
Here is my Log
dt << select Where( :age == 12 );
n = Col Sum( :age, Selected/*###*/() );
Row number not set or in range in access or evaluation of 'Selected' , Selected/*###*/()
Best
Uday
uday_guntupalli
Level VIII
@ian_jmp  / @ms / @txnelson  - Any thoughts ?
Best
Uday
ms
Super User (Alumni) ms
The Col Stat() functions are mainly useful in column formulas, and with optional grouping arguments they do not work at all as stand-alone functions (then use Summarize() instead).
My old post was intended to show how to update a column dynamically just by selecting rows by hand (or by script). More of a neat trick than anything very useful...
Example:
dt << New Column("Conditional sum", Formula(Col Sum(:age, Selected())));
dt << select Where(:age == 12);
// Or select rows by hand and see how numbers change dynamically
What you want to do is to use the ability to reference values in a data table as a vector of data, and pass to it the matrix of the selected rows
n = Sum(:age[dt << Get Selected rows]);
uday_guntupalli
Level VIII
@txnelson :
       Thank you . While I am familiar with this approach - what surprised me was the way @ms was solving the same problem .
dt << New Column("Conditional sum", Formula(Col Sum(:age, Selected())));  // This Works
n = Col Sum(:age,Selected());  // This yields an error
     While I understand that line 4 can be easily replaced with your solution i.e. and that is my goto solution,
n = Sum(:age[dt << Get Selected Rows]);
     I dont understand why this line of code is resulting in an error in my case .
    The documentation doesn't show that this feature exists ( atleast in JPM 12)  - so was really excited by this new trick but it seemed to work in the case @ms Solved the question earlier. Can either of you explain why the exact same code works in a column formula but throws an error outside ?
Uday
Best
Uday
Your example code:
The Col Sum() function operates differently in open code vs. in a formula.  When processing, the data, in open code, if the second element is present, JMP cannot execute the statement since the resulting value is going to return more than one value.  That is, the returned value in your example would require the variable "n" to have 2 values.  The Col Sum() for selected rows and the Col Sum() for non selected rows.  I suppose, that JMP could return a list of values, but as @ms indicated the Summarize() function is used for this.  Therefore, the reason the second element in the Col Sum() function is not valid in open code.
View more...
twillkickers
When I use
Col Sum( :ColumnName, Selected() )
I get the following error:
Could somebody tell me what might be happening?
