guyon
Col Shuffle for multiple groups
I have a dataset with several samples and each sample has 10-30 measurements in separate rows. I want to be able to assign a random value from 1 to the number of measurements for each sample. I can use Col Shuffle to randomize but it requires subetting the data into several tables and applying a formula to each subset before updating the original table with the randomized numbers. Is there a method to do this with one equation?
pmroz
Re: Col Shuffle for multiple groups
Try something like this:
// Create a test table
dt = New Table( "Sample Measurements", Add Rows( 13 ),
     New Column( "Sample", Character, Nominal, Set Values(
                {"A", "A", "A", "A", "A", "B", "B", "B", "C", "C", "C", "C", "C"} ) ),
     New Column( "Measurement", Numeric, Continuous, Format( "Best", 12 ),
           Set Values( [65, 76, 23, 43, 67, 65, 546, 34, 64, 76, 32, 67, 88] )
// Add a random column
dt << New Column( "Random Value", Numeric, Continuous, Format( "Best", 12 ),
     Formula( Random Uniform() )     );
// sort
dt << sort(replace table, by(:Sample, :Random Value));
// Add a sequence column
dt << new column("Sequence", numeric, continuous);
// Add sequence values
old_value = "XYZZ";
for (i = 1, i <= nrows(dt), i++,
    sample_value = dt:sample[i];
    if (sample_value != old_value,
        old_value = sample_value;
        k = 1;
    dt:sequence[i] = k;
    k++;
vince_faller
I assumed 2 columns, 1 named sample and 1 named Values.
dt = current data table();
samples = Associative Array(:Sample);
dt<<Sort(By(:Sample), replace table);
for(i=1, i<=Nitems(samples), i++,
      rows = dt << get rows where(:Sample == samples[i]);
      start_row = min(rows);
      end_row = max(rows);
      samples[i]= :Values[Random Integer(start_row, end_row)];
show(samples);
Vince Faller - Predictum
pmroz
// sort
old_value = "XYZZ";
        k = 1;
    dt:sequence[i] = k;
    k++;
guyon
This worked thank you!
