swaiper
Data Filters - auto-update
I have a problem on my app create with the App Generator.
I have created a window with an histogram, and an table (both on the same window). When i select rows in my table, my histogram is automaticly updated.
But my problem is when I try to had a filter box on the same window :
pDate <<launch(
df = ds << Data Filter(
Local,
columns( Eval("File Date") )
My data filter is launch, but when I try to move the slidder of de the date, my table and my histogram doesn't uptade.
I have found thisone in exemples scripts index :
df << Make Row State Handler( ds );
But it doesn't work too. I just had this line after my filter, maybe it's not the good place.
Thanks per advance for your help
Re: Data Filters - auto-update
The Local Data Filter works in combination with a Data Filter Context Box, which tells the Data Filter which reports you want to filter.  If you want to filter the entire window, just select the top-level box and select Data Filter Context Box from  the toolbar:
If you have multiple reports you can use this box to filter only one of the reports, but you do have to make sure that both the filter and the report are within the Data Filter Context Box.
Hope that helps!
-Dan
Hope that helps!
-Dan
swaiper
Thank you for your answer, but it's not working fine.
I try to do this. But my filter work only on my TabulateBox, not on my graphs. I don't understand why.
I put the DataFilterContext on all my window. I think put this context on my garphs contener will work but it didn't.
Just a screen to see my app and maybe help :\
You can see my filter is apply to my Tabulate, but not on the two graphs builder.
Thanks per advance for your answers.
Romain
swaiper
I resolve my problem. It's because I launch my Filter not with a good way.
Problem solved.
Thanks a lot.
XanGregg
The data table is more of a source object and doesn't respond to data filter exclusions if that's what you mean. However, you can get the exclude effect (but not the selection linking) with a Tabulate table instead.
To get Tabulate to show the data instead of a summary, I added a nominal unique ID column called "row" (name is not unique here because there are two Roberts).
