Re: Col Cumulative Sum by group increases counter if first row is missing or empty
This widget could not be displayed.
Created:
Jul 19, 2022 08:45 AM
| Last Modified: Jul 19, 2022 5:45 AM(530 views)
| Posted in reply to message from FN 07-19-2022
I replicated you findings. There also seems to be a relationship between missing values and the starting value of zero. Put a valid, but non zero value in row one and different results are shown.
Please turn your findings into the JMP Support team
Created:
Aug 1, 2022 04:41 PM
| Last Modified: Aug 1, 2022 1:41 PM(488 views)
Thanks so much for reporting this - we have replicated the issue in the Development team and it is on track to be addressed in a future version of JMP.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '523325' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if (newSub.getAttribute("slang").toLowerCase() == code_l.toLowerCase()) {
if (value == '523325') {
else{
} else {
sub_L = newSub.innerHTML;
try{
catch(e){
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
