bzanos
Code to Check If No Row Created in a of Data Table, Close the Data Table
I am creating a list data table subset from a main data table. Then, I manipulate the data through Tabulate() and make into the table for processing. Then, check each of the data table N Rows, if N Rows = 0, close the data table. Finally, append the data table into the report. Below is my script.
The problem is after I add in below codes, to check the N Rows, it no longer work. No error show up.
If(N Rows(mDT)==0, Close(mDT, no save));
I believe might be some error on the code. The overall code might not be well written
Need guideline and help here.
saveFolder = "$TEMP/";
listDT = {};
listtab = {};
mDT = {};
col = Column(dt1Sub, ":PART");
colLevs = Associative Array(col) << Get Keys;
hb = V List Box( );
For (i=1, i<=NItems(colLevs), i++,
     r2get = dt1 << Get Rows Where(:PART == colLevs[i]);
     listDT[i] = dt1 << Subset(Rows(r2get));
     listDT[i] << Set Name(Char(colLevs[i]));
     listDT[i] << Save( saveFolder || Word( 1, listDT[i] << get name, "-" )||".csv");
     listtab = listDT[i] << Tabulate(
	               Show Control Panel( 0 ),
	               Add Table(
		               Column Table( Grouping Columns( :ORDER ) ),
		               Column Table( Statistics( Sum ), Analysis Columns( :Qty ) ),
		               Row Table(
			               Grouping Columns(
				              ::PART,
				              ::PART DESC,
				              :LOW PART #,
				              :LOW PART DESC,
				              :FAILURE MODE
     mDT= listtab << Make Into Data Table;
     Close(listDT[i], no save);
     mDT << New Column ("Criteria", Character, "Nominal",
     	      Formula(
     	      	If(As Column(6)>= 3, "Failure")
     mDT:Criteria << Delete Formula;
     mDT << Sort(By(Column(6)),Order(Descending), Replace Table);
     mDT << Select Where (:As Column(6) == 0);
     mDT << Delete Rows;
     mDT << Set Window Size (2400, 800);
     mDT << Get As Report;
     hb << Append( ( mDT << Get As Report ) );
New Window( "Report", hb );
Re: Code to Check If No Row Created in a of Data Table, Close the Data Table
It could be that you continue the loop execution after closing the datatable. You could try moving the rows in for loop after if-statement to else statement:
If(N Rows(mDT) == 0,
	Close(mDT, no save)
,//else
	mDT << Set Window Size(2400, 800);
	hb << Append((mDT << Get As Report));
or useContinue() after closing mDT:
	Close(mDT, no save)
	Continue();
You are attempting to pass messages to your mDT object even when the table has been closed.  See if the JSL below works for you
listDT = {};
listtab = {};
mDT = {};
col = Column( dt1Sub, ":PART" );
colLevs = Associative Array( col ) << Get Keys;
hb = V List Box();
For( i = 1, i <= N Items( colLevs ), i++,
	r2get = dt1 << Get Rows Where( :PART == colLevs[i] );
	listDT[i] = dt1 << Subset( Rows( r2get ) );
	listDT[i] << Set Name( Char( colLevs[i] ) );
	listDT[i] << Save( saveFolder || Word( 1, listDT[i] << get name, "-" ) || ".csv" );
		Add Table(
			Row Table(
				Grouping Columns(
					::PART, ::PART DESC, :LOW PART #, :LOW PART DESC, :FAILURE MODE
	mDT = listtab << Make Into Data Table;
	Close( listDT[i], no save );
	mDT << New Column( "Criteria",
		Character,
		"Nominal",
		Formula( If( As Column( 6 ) >= 3, "Failure" ) )
	mDT << Sort( By( Column( 6 ) ), Order( Descending ), Replace Table );
	mDT << Select Where( :As Column( 6 ) == 0 );
	mDT << Delete Rows;
	If( N Rows( mDT ) == 0,
		Close( mDT, no save )
		mDT << Set Window Size( 2400, 800 );
		hb << Append( (mDT << Get As Report) );
	Close(mDT, no save)
,//else
	Close(mDT, no save)
	Continue();
listDT = {};
listtab = {};
mDT = {};
hb = V List Box();
		Add Table(
			Row Table(
				Grouping Columns(
		Character,
		"Nominal",
	mDT << Delete Rows;
bzanos
it work perfectly. Thanks Jim and Jarmo
