DMR
DMR
Level V
Closing data tables automatically when a window is closed
I have a script which produces both a data table and a window which contains some charts derived from that data table.  I'd like to arrange for the data table to be closed if the user closes the chart window.  How do I do that please?  I've tried using the "<< on close" property of the window, but am evidently doing something wrong as it appears to be having no effect.
(Obviously I could add a button within the window to close the window that way and tell the user to click on it, but there's no guarantee that they'll actually do that: some users will simply close the window by means of the "X" button at the top-right.)
Many thanks in advance.
ian_jmp
Level X
Re: Closing data tables automatically when a window is closed
From memory you need the 'OnClose()' message immediately after the window title. It's really quite useful for housekeeping (like closing invisible tables) and other things.
ian_jmp
Level X
DMR
DMR
Level V
Perfect!  Many thanks Ian.
