nathan-clark
Close Web() jmp window
In order to be able to open a sharepoint file, I'm using the Web(url, jmp window) command to open in JMP and then subsequent commands to access the data.
Is there a way to close the web window? Currently it seems the user needs to close it down, but since it's only being open to trigger credentials so JMP can actually do something with the file, it would make more sense to close the window.
I'm not finding the syntax to let that happen.
Thanks!
Re: Close Web() jmp window
Maybe you can access it directly with window name? This seems to work
Web("http://www.jmp.com/", JMP Window);
wait(1);
Window("Web Browser") << Close Window;
wait(1);
nathan-clark
Thanks! Worked like a charm.
