albiruni81
Classical Screening design vs Definitive Screening Design
Hi All,
Anyone can give me a summary of difference between a classical screening design and DSD? What are the advantages and disadvantages between this two methods
Rgrds
Irfan
11 REPLIES 11
albiruni81
Re: Classical Screening design vs Definitive Screening Design
Hi Jim,
When i do this power analysis, any reason that the model comparison is showing that the fractional factorial is superior than the DSD
Rgrds
Irfan
You lose power and estimation efficiency due to the center levels for each factor.They have no leverage in estimating the parameters for the main effects. You gain the ability in a true screening situation to (possibly) avoid additional runs (augmentation) in order to model higher order terms.
Search the JMP Community Blogs for "definitive screening designs" for more details and background information. (Easier for you than 'back and forth' with a lot of questions.)
